2.3L 4cyl or 3.0L V6, 6th Generation
428 Questions View all
Why are my dash lights not working?
I have a 98 honda accord EX and my dash lights do not work properly (they don't turn on). I have tried to adjust the brightness switch, nothing. Their is an aftermarket sony deck that came with the car at the time of purchase. I've read that that may have caused the problem...
Score 1
7 Comments
Dash light and tall light dnt work but my brake light do work why
by
My dashboard lights not coming on inside my 1999 Honda accord
by
My Honda Accord euro 2004 dash light and tail light not working
by
My dashlights stopped working and my SRS light is staying on now.
by
Me too Angel kay Hewitt what did you do?
by
Show 2 more comments
Add a comment
Most Helpful Answer
Here's a discussion on the same problem with someone who also added sound stuff:
http://honda-tech.com/showthread.php?t=2...
Score 3
Add a comment
Check the wire harnesses in where the passenger side fuse box is, on my car one of the plugs had a loose connection that was causing my dash lights and park lights not to function
Score 2
2 Comments:
Most Definitely a fuse or a loose wire in the fuse box.
by
I will know for sure tomorrow and hopefully that can help you with your a car problem.
by
Add a comment
With an aftermarket stereo you should check, I beleave if memory serves mo correctly, itsmthe Orenge wire. It's for the dimmer on the stereo. 9n mine it took out the Multiplex controller modual. I went past it and jumped 2mwires I now have dash lights. Pnly thing is , no more dimmer, the dash lights are on high all the time, I don't mind mine were a little too dim for me anyway ......Good Luck !!!!!!
Add a comment
Add your answer
Oluseun will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 47
All Time: 36,577
